Climate Control Panel Display
Old May 6, 2010 | 12:07 AM
tangoloco's Avatar
Default Climate Control Panel Display
The display in my climate control panel has been really dim for over a year. Now the level of illumination is very erratic. Most of the time when I first turn the ignition on, the display will be quite bright. However, within about 5 minutes I won't be able to see anything at all.
My independent repair shop tells me all they can do is take it to an electronics place, and it will probably be at least $200 just to take the unit out to test it. Is there any other way to troubleshoot this problem?
Old May 8, 2010 | 11:59 PM
Dave01's Avatar
You need to remove the climate control circuit board and resolder its resistors. Here is a link that shows the steps required to do this.
http://www.brookins.us/accontroller/index.html
The circuit boards shown are in 2000-04 C5s, I believe. Older C5s have boards that look a bit different. There should be two boards in the temp controller box that you need to remove. The board having the poorly-soldered resistors is the one in the back of the box. I resoldered mine, last year.
Old Oct 13, 2010 | 10:00 AM
fjf0302's Avatar
perfect. im going to fix mine now. thanks.
pewter2000
Dec 19, 2008 12:19 AM
Genocide
Dec 28, 2006 05:52 AM
mcat1212
Dec 27, 2006 08:46 PM
acossey
Jul 9, 2006 03:06 AM
Billromans
Oct 29, 2005 02:36 AM
