Front Wheel Bearing Replacement
Old Mar 26, 2013 | 05:43 PM
csyvarth's Avatar
Default Front Wheel Bearing Replacement
Had my 2001 in for an oil change, and was told the front wheel bearings need replacing, $869.00 for the job. I found Simkin bearings for $369.00 and need to know if $500 labor to install them is reasonable. I will gladly pay it, but it is my first vette and want to be sure I'm not being taken. Thanks for any advice. Charl
Old Mar 27, 2013 | 10:33 PM
Dave01's Avatar
Apparently, Timkin is the way to go with their $180 cost being significantly less than the equivalent SKF bearings. Since they are not too dificult to replace, there's probably no need to have to go to a dealership. Most alignment shops do this on a regular basis.
Old Mar 31, 2013 | 06:01 PM
vettex2's Avatar
I've changed them myself w/o an alignment
it takes about an hour to swap bearings on one side , max......on a rack , about an hour , with air tools for both......
Old Apr 28, 2013 | 10:58 AM
vettex2's Avatar
Originally Posted by LilGreenBooger
This guy would know, just look at his sig line - professional nascar tire changer!
I would know because I've done them as well as building championship cars
csyvarth
Mar 26, 2013 05:42 PM
74vett
Jul 9, 2007 02:11 PM
sleeprrr
Feb 15, 2007 11:57 PM
scotto
Jun 18, 2006 02:16 AM
jetmech09
May 18, 2006 02:05 AM
