how do i cange oil? (dont laugh)
Old May 8, 2006 | 01:37 AM
predator's Avatar
Default how do i cange oil? (dont laugh)
i know how to change friggin oil... but not on a car that is 2 inches off the ground... can i jack up the front and put stands under it or will that put it at a bad angle? where do you advise jacking and putting stands? what kind of oil? how many quarts? what brand filter? im comming up close to 40k miles any thing i shoudl check while im diggin around?
thanks... and yeah yeah yeah i know there is a plug you take out and a filter you unscrew... ha ha ha... no seriously
-me
Old May 8, 2006 | 09:32 AM
Default RE: how do i cange oil? (dont laugh)
Shouldn't have any problems jackin up the front end and putting jack stands under it since the oil drain is in the back of the pan.
Old May 8, 2006 | 12:04 PM
predator's Avatar
ok now on to more specifics on jacking it up... and oil type and so forth...
-me
Old May 9, 2006 | 02:09 AM
Dave01's Avatar
I used to drive up on Rhino ramps, but after I lowered my C5, that became impossible. So, I cut some low-profile (10 degree) ramps out of 6 x 6 lengths of wood. With one of these in front of each tire, I drive up high enough to get my 19-inch hydraulic floor jack under the front crossmember. (in its cradle is a PVC disc to protect the aluminum crossmember). I then jack up the front high enough to place jack stands underneath and then do the same in the rear. Alternatively, you may be able to jack up one corner at a time using a jacking puck and a low-profile aluminum racing jack.
If you have tons of money, "Racing Ramps" will do the trick ($200 a pair).
As for oil - Mobile 1, 5W-30, 6.5 quarts (buy 7, of course)
oil filter: K&N (has a welded-on nut for easy unscrewing and tightening)
Don't forget to change your antifreeze every 5 years. Other than that you should be good to go.
terl30
Sep 20, 2009 10:39 PM
wrwalke
Mar 19, 2007 04:14 PM
Kobegotskillz
Jan 31, 2007 02:00 PM
3BlkC4Ragtop
Dec 25, 2006 01:28 PM
89rdstr
May 16, 2006 09:20 AM
