View Poll Results: Installation of fixed headlights from Corvette Mods
Will the Corvette mods lights work
0%
Is there a fix for this problem
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old Oct 18, 2021 | 11:24 AM
USSKNOX's Avatar
Default Installation of fixed headlights from Corvette Mods
I purchased a pair of fixed headlights from Corvette mods. I installed the brackets as instructed. When I placed the headlight in the opening there was a gap around the new headlight. I made the connection to the wiring harness, new light to car light harness, & found 2 connections to the high beam with no place to connect them. I also have a male connection without a place to connect it. I am a first time owner of a 2001 C5. Has anyone else had this problem ? Is there a way to make this work ?
Old Oct 19, 2021 | 10:38 AM
Welcome to the forum. Have you contacted the vendor to see if they have any solution?
Old Oct 19, 2021 | 11:13 AM
USSKNOX's Avatar
Default Fixed Headlights
When I purchased the lights I asked about installing them. I was told they would slip in, & all connections were plug in. Since I installed the brackets I found afound 1/4" gap around the light. I contacted the seller Corvette Mods, & sent the photos they requested. They told me I installed them wrong. They then told me that the lights had to be installed by a body shop. If they had said that in the beginning I would not have bought them. I also found that the connection for power to the high beam does not exist on my 2001 car. So both high beams, L&R can't work at all. So far after I told them, about no electrical supply to both high beams I have not heard from them. So I wait.
USSKNOX
Old Oct 19, 2021 | 04:10 PM
If you check their reviews online, you'll see that this is their standard operating procedure.
Old Oct 19, 2021 | 05:26 PM
USSKNOX's Avatar
Default The latest from Corvette mods
They just told me no return, because the headlights are used. They said they provided instructions & my attempt basically is on me. There was no attempt to resolve the issue except refusing to accept a return. They did not acknowledge that their representative did not tell me that a trained installer was required. They made no attempt to explain their selling hi beam headlights to me which won't work because there is no power supply available for hi beams.
So the lesson is buyer beware !!!
Old Oct 19, 2021 | 11:12 PM
That sounds like several of the reviews I read online about this company.
Old Oct 20, 2021 | 07:43 AM
USSKNOX's Avatar
When I first saw this Company there were a lot if positive reviews. The review I wrote is not positive. Don't know if it got on their site.
fatoms
Sep 1, 2024 10:49 PM
BabyHerC5
Sep 17, 2018 08:50 AM
lbelew
Aug 29, 2007 09:37 PM
racerrick
Jan 8, 2007 12:18 AM
steelman09
May 17, 2006 09:31 AM
