Headlights not popping up
Old Jun 28, 2018 | 11:43 PM
BabyHerC5's Avatar
Default Headlights not popping up
Hey, has anyone had issues with headlights not popping up? Still lighting up, doesn't sound like the motor. Not sure where to start.
Old Jun 29, 2018 | 07:03 PM
Is 12 volts getting to the headlight motors when you try to raise or lower them? If not then you need to go back and see where you're losing the 12 volt signal
Old Aug 10, 2018 | 09:10 PM
BabyHerC5's Avatar
Default Headlight not popping up
Thank you for answering. Where do I look to see if 12 volts are getting to the headlight?
Old Aug 10, 2018 | 11:19 PM
I would start by measuring the voltage at the connector at the headlight motor itself. You can do this with either a test light probe or a digital multimeter.
Old Sep 16, 2018 | 03:49 AM
BabyHerC5's Avatar
Hi, well, the headlight popped back up one day. It's been two weeks now, and when I shut them down there is a low rumble, growling sound after they go down. I don't know what's happening. Anyone had this happen and know what it's doing? Thanks
Old Sep 16, 2018 | 11:06 AM
Now it sounds like the plastic gears need to be replaced by the available metal gears in the aftermarket.
Old Sep 17, 2018 | 03:26 AM
BabyHerC5's Avatar
I thought it might be more serious. Any recommendations on where to buy aftermarket parts? I haven't had very good luck getting good parts from carparts.com.
Thank you!
Old Sep 17, 2018 | 08:50 AM
You will need to go to the Corvette aftermarket suppliers such as Corvette Central, Wilcox, Zip, etc. Try Googling Corvette headlight motor metal gears and see what you get.
fatoms
Sep 1, 2024 10:49 PM
MikeAnthony
Technical Diagram Help
Oct 19, 2017 02:01 PM
JoeVetteman
Sep 2, 2008 12:53 PM
C3 Starship
Aug 30, 2006 08:41 PM
HRS84VETTE
Feb 12, 2006 10:40 AM
