Headlights
Old Aug 27, 2007 | 09:12 PM
lbelew's Avatar
Default Headlights
Just wondering if anyone else has encountered this. When I turn on my headlights, the doors open but the normal and hi-beams do not work. The flash function works and both lamps, hi and low come on. Also if I turn twilight sentinel on both headlights come on as advertised. Thanks.
Old Aug 29, 2007 | 09:37 PM
Default RE: Headlights
ORIGINAL: lbelew
If s device ain't got power at all, it's sure a lot easier than checkin' for correct voltage.
Since BOTH lights don't work, you know it's not a faulty ground at one headlight.
Find out where power splits off to go to the two lights from one point (maybe the headlight switch itself - check the wiring diagram), but the split-off point is where you gotta' start checkin' for power absence, when there should be power.
Follow the wire UPcurrent till you find the problem.
Wrangler47
Jun 24, 2006 08:08 PM
t1vette
Apr 26, 2006 12:38 AM
HRS84VETTE
Feb 12, 2006 10:40 AM
99hdtop
Oct 19, 2005 10:08 PM
wterwal
Sep 7, 2005 11:21 PM
