installing an exaust system
Old Oct 31, 2008 | 11:35 AM
ttlusty's Avatar
Default installing an exaust system
Hi all,
Is it possible to install an exaust system (mufflers) on an '04' in your own driveway without having to take it into a shop to have it done?
Old Nov 5, 2008 | 05:18 PM
chargedvette02's Avatar
Default RE: installing an exaust system
I did with out any problems. I only had a jack and jack stands. I also just did an exhaust on my Subaru STI with only a jack and jack stands.
Old Nov 5, 2008 | 07:46 PM
It is easier the higher off the ground you can get the car. Jack stands or a set of ramps get it up a bit but sits a squirn and twist job underneath with only that much ground clearance. If you can rent a space in a garage with a lift it may be worth it, but you can do it in your drive way if you don't mind contorting a lot.
Old Nov 8, 2008 | 02:09 AM
Dave01's Avatar
You have to get the back end up about 39 inches and we had to swing the sway bar out of the way to get the right side pipe out. I used 6x6 wood piled on my floor jack, but don't get your body under the car while in that state!
Old Nov 10, 2008 | 08:03 PM
JustFlyn's Avatar
Hate to wimp out on this one, but I had Mid America Motor Works install a set of Corsa's on mine. The installation was only $100 - and was done by professionals that really care for Corvettes. I thought for the money, it was well worth it. They are in southern Illinios, but they also sponsor a huge Corvette show just west of Chicago about the 3rd week in June. They have install shops right on the grounds andcan install anything you want as you wait.
ttlusty
Oct 31, 2008 12:01 PM
Joseph75
Nov 4, 2006 10:19 PM
jmtrotzie
Sep 22, 2006 08:02 PM
jaxmike
Aug 28, 2006 08:10 PM
Krayon
Nov 5, 2005 09:24 PM
