Lifting a C5 convertable
Old Aug 23, 2006 | 11:41 PM
jaxmike's Avatar
Default Lifting a C5 convertable
Hello all
Just picked up my first vette. Its a 2001 Red convertable. What a feeling ridding in that car with the top down.
The first thing I paln to do is replace the exaust. Still doing research on what brand. A friend of mine said you have to be very careful when a shop lifts your car to do any work. Is that a urban myth or is it something I need to be aware of.
Thanks in advance
Mike
Old Aug 24, 2006 | 12:51 AM
Dave01's Avatar
Default RE: Lifting a C5 convertable
That is very true. Lifting pucks are available that fit into a slot in each side of the underside of the car. These pucks prevent paint damage in those areas.
Here's what they look like:
http://corvettespecialty.com/corvett...roducts_id=435
Dave
Old Aug 24, 2006 | 01:13 AM
gorichb's Avatar
Yea don't let them shops tell you otherwise. i bought a set of these lifting pucks for my 98, and you could bet I'll have them in there anytime I take it to a shop for anything.
Old Aug 24, 2006 | 09:18 AM
jaxmike's Avatar
Thanks guys. Set ordered.
Old Aug 24, 2006 | 02:24 PM
TopSpeed's Avatar
ORIGINAL: Dave01
Dave
Dave, wow... is this only for C5's?
Old Aug 24, 2006 | 06:03 PM
Dave01's Avatar
TopSpeed,
I don't think they are necessary when jacking a C4:
"The pinch-welded rib on the frame runs the entire length of the lower facia (where the jacking arrows are) and if you place the jack pad midway between the front and rear arrows, you can safely rasie the entire side.
Look under the car along the frame rail and find a stud that is used to support the brake lines (driver side) and fuel lines (pass. side) Just place the jack pad in front of or behind that stud and lift the car. Place stands at the front and rear, and then go to the other side and lift in the same way."
Dave
Old Aug 24, 2006 | 07:46 PM
TopSpeed's Avatar
ORIGINAL: Dave01
TopSpeed,
Dave
Thanks Dave, I appreciate your input. I have a mechanic I've been going to for the better part of 20 years for all my muscle cars... do I need to pass the info you just posted here with him, or do you think it's safe to assume he already knows that? He's not a Corvette specialist, per se, but has worked on a ton of them before....
Old Aug 25, 2006 | 01:46 AM
Dave01's Avatar
I would ask him what he uses to jack up C4s. Let us know and we'll tell you what we think. I'm sure if he's done others, he knows what he doing, but it never hurts to find out for your own knowledge.
Old Aug 26, 2006 | 01:57 AM
rjensen's Avatar
Thanks for bringing this lifting problem to our attention. I just bought my set, too
Stay safe.
RJ
'04 C5 Silver Coupe
Borla Stinger 7.5" Dual Pipes
Sweeet!
Old Aug 30, 2006 | 04:05 PM
TopSpeed's Avatar
ORIGINAL: Dave01
Thanks dude! I have to book an app't next week to troubleshoot our climate control problem, I'll ask him and let you know what he says. Really appreciate that, Dave! You rock. [8D]
mll489
Corvette C6 Z06
Aug 2, 2008 06:05 PM
Phill
Jan 27, 2007 02:09 AM
gorichb
Aug 30, 2006 05:41 PM
jaslederer
Jul 22, 2006 07:44 PM
jmrazz
Oct 6, 2005 11:25 AM
