New C5 Seats Shim Dont work on all C5s!!
Old Aug 28, 2009 | 05:28 AM
dheller1's Avatar
Default New C5 Seats Shim Dont work on all C5s!!
C5 Shim Kit to prevent seat rocking
http://www.corvettepartsblog.com/new...pair-shim-kit/
These shims do not fit my 2003 C5 Z06, I am the only owner of this car so they are the factory tracks. They are about 1mm too wide and there is no way they will fit correctly even if I try to force them. They will fit inside the block, the end of the block is tapered where they need to seat. The directions are not 100% correct for the 2003 Z06 seat track, this track does not use the small torx in the kit, I had to go buy a torx socket. Was this kit only intended for C5 coupe only, are there different power seat tracks? Somebody did not do their homework 100% before releasing this product.
Follow Up
I have found that the Company that makes the shims has poor customer service, I was told my car is no different than any other vette. Ok, I have pics and measurments so why do they not fit my track? Then I was told to file them down to make them fit or shave them down with a knife, ok my car is the same as all other vette but I am supposed to file down a plug and play kit that I paid $25 for? I asked if they could send me a few extra shims incase I screw one up and I was told to take a hike. Great way to do business, basically if they don't fit shove it up your %^& and it is you problem to deal with!
Thumbs down on this product! If it works it works, if it does not work too bad your problem to deal with!
YZSoFast
Jun 24, 2007 08:22 AM
Black86vette
Mar 31, 2007 09:30 PM
maiden
Nov 28, 2006 09:53 AM
89rdstr
May 16, 2006 09:20 AM
predator
May 9, 2006 02:09 AM
