New Key
Old Oct 4, 2007 | 09:55 AM
Bull's Avatar
Default New Key
I just picked up a 98 Coupe, the owner had one key plus a new blank he had order from the dealer. Can any hardware place cut the key or does it required a Chevy dealer cut it and possible activate chip in key?
Old Oct 4, 2007 | 03:36 PM
rshiver's Avatar
Default RE: New Key
They should be able to cut the key with no problem. I don't thinkit has to be activated, it's just a resister embedded in the key.
Old Oct 5, 2007 | 08:37 AM
Bull's Avatar
Default RE: New Key
Thanks, I called the dealer and the lady at the service center said, yes,, I will call the part department, what you said makes much more sense
Old Oct 6, 2007 | 11:34 AM
Bill K's Avatar
Default RE: New Key
Any locksmith can cut it, You might check and make sure the resistor is the same on both keys before cutting it..
Old Oct 6, 2007 | 04:19 PM
Default RE: New Key
"The keys have to be the same resistance or you will have to go through a "learn" process that requires a Tech 2 scan tool and takes about 12 minutes.
byedan1
Aug 20, 2006 01:45 PM
rockyneil
Corvette C5 Z06
Apr 22, 2006 12:13 AM
SyTyJim
Dec 11, 2005 11:05 PM
jdavis
Jul 17, 2005 03:31 PM
LLL
Jun 15, 2005 04:33 PM
