NO BRAKE LIGHTS
Old Nov 11, 2008 | 02:59 PM
gigabyte's Avatar
Default NO BRAKE LIGHTS
No brake lights.....everything else works. What is the problem? 03 LS1 6 speed
Checked: fuse is good
flashers work
turn signals work
running lights work
bulbs are all good
center brake light works
backup lights work
license plate light works
Plugged in a differant rear harness with same results.
I'm stumped!
Old Nov 11, 2008 | 09:14 PM
Dave01's Avatar
Default RE: NO BRAKE LIGHTS
Have you checked for 12 volts at the brake light connectors when someone is tepping on the brake pedal? If there is no voltage, the brake light switch may be bad. If there is voltage, then your bulbs are bad.
Old Nov 12, 2008 | 06:45 PM
gigabyte's Avatar
That is something I did not think of. Is it in the usual place that I can reach from inside the care without ripping my interior out or should istart looking on the firewall? I guess I don't know were to look on a vette.
thanks for the first response
Old Nov 13, 2008 | 03:18 PM
Dave01's Avatar
Are you saying that you DID check for voltage at the tail lights? I would check the brake light switch ONLY after ensuring that there is no voltage at the tail lights when you're braking.
The brake light switch should be under the brake pedal somewhere. I'd put the seat all the way back, grab a flashlight and take a look.
Old Nov 15, 2008 | 01:28 PM
gigabyte's Avatar
I did not check voltage at the tail light socket. I will do that, but was thinking that all four lights going out at the same time would pretty irregular. You never really know until you test......
thanks again
Old Nov 15, 2008 | 07:12 PM
Dave01's Avatar
I've seen it happen before!
Good luck.
blackhawk
Mar 11, 2009 04:07 PM
iwantfast
Sep 24, 2008 10:41 PM
shevey
Sep 23, 2008 10:19 PM
IVAN1215
Technical Diagram Help
Sep 24, 2007 01:50 PM
vettemanrob
Sep 22, 2006 09:59 PM
