Oil Level
It's probably not as important when you check it as it is to be consistent and form a habit of checking it. You will see a different level depending on how warm the engine is,how long you let it drain down and so on. For many folks the best time is when you're fueling. Gives you something to do while the gas is running in. Start the gas,pop the hood check the oil,brake fluid,power steering fluid,wash the windows,kick the tires.....well maybe not kick the tires. The important thing is the habit!
Ron
Ron
