TIRE HUM
Old Jan 16, 2008 | 04:10 PM
lakesidebob502's Avatar
Default TIRE HUM
Recently purchased a 2001 convertible with 295/35ZR18's on the back. Wider than traditional stock size.
As I approach about 50 mph I start to hear this "rythmic-type hum" coming from what sounds like the rear. As I increase speed, it gets louder. The tires are New.
A friend tells me that it's the nature of the beast with the wider tires.
IS this true?
Old Jan 17, 2008 | 01:25 PM
bados's Avatar
Default RE: TIRE HUM
Usually high performance tire produces some road noise. Are those wide tires on a different rim? I wouldn't think they would fit on the stock one.
Old Jan 17, 2008 | 05:42 PM
Yes...the rims are wider as well to accomodate the larger tires.
Old Jan 18, 2008 | 11:01 PM
Dave01's Avatar
What brand and modeltires are they. The BF Goodrich KD 2s are louder than most. But as a general rule - no, tires should not howl. Hopefully, it's not the differential that's howling.
Old Jan 19, 2008 | 06:48 AM
Just learned it is the hub bearings that are bad (not cheap).
Thanks for your comments.
Old Jan 19, 2008 | 12:08 PM
KenHorse's Avatar
I once had someone ask me if I knew why *his* tires hummed. I told him because they don't know the words....
Glad you found the problem!
Old Jan 30, 2008 | 09:57 AM
moscooter's Avatar
" But as a general rule - no, tires should not howl."................Too bad I didn't record it and you're not around to hear it, but that statement is FALSE!!!
My wifes brand new '87 Vette came stock with Goodyears on it. We lived in a cul-de-sac and if I was out in the driveway, I could hear her coming home from work out on the main road before turning into our street. I once owned a Chevy Blazer and in the winter I had 4 snow tires on it (4WD). It was loud, but the Vette was as loud or louder.
When the Goodyears wore down and I had them replaced with Michelins, No more howling tire noise.
dans87vette
Jun 20, 2007 03:57 PM
May 31, 2007 03:40 PM
Anita
Jul 25, 2005 05:30 PM
bRKrbcing
Jun 29, 2005 03:25 AM
kstrbss111
May 14, 2005 11:22 PM
