Traction System/ABS System lights on
Old Mar 6, 2018 | 08:35 AM
RKO001's Avatar
Default Traction System/ABS System lights on
The warning lights for the TS and the ABS come on intermittently on my 2000 C5. It happens usually when in encounter a rough road. I am hoping, as I have been told, that it may be a loose ground. I had a dealer check it out but they indicated all sorts of electronic replacements were needed....$6000. plus. Whenever they come on, they stay on for a long time.....mostly go off when I again encounter rough road or bumps. Is it ok to drive in this state? I know, stay off rough roads! Thanks, been told that. LOL. That's hard to do here in the Blue Ridge Mtns of Va. Any help appreciated!
Old Mar 7, 2018 | 08:31 AM
You might check the wheel speed sensors and their connections.
Old Mar 29, 2018 | 03:42 AM
achesley's Avatar
Have you checked the codes yet? I had that problem and it was the 1214 code which I had to take the ECBM apart and resoldier the contact joints. No problems since then.
