blower motor will not turn off.
Old Jun 3, 2018 | 09:33 PM
mowenboss's Avatar
Default blower motor will not turn off.
I have a 98 Corvette, and tonight when I pulled it in the garage shut the motor off and remove the key the fan motor was still running. Can anyone tell me the problem? Please!
Old Jun 4, 2018 | 01:56 PM
The first thing I would check would be the switch itself. Did you try all speeds on the blower? The second thing I would check would be to see if the ground circuit had been pulled to ground in the wiring harness someplace. Has there been any work done recently in that area?
Old Jun 6, 2018 | 09:17 AM
mowenboss's Avatar
No no work has been done and the switch doesn't do anything it is continuously on high
Old Jun 6, 2018 | 09:18 AM
mowenboss's Avatar
Other discussions about the topic mentioned the blower control module, and it sounds like it might be what's going on what do you think?
Old Jun 7, 2018 | 10:14 PM
Could be. Older models used a relay on High and if yours does, then the relay could be stuck. But if there's a blower control module, then that might be it.
rdgeno
Nov 10, 2014 10:50 PM
Bigdenny
May 27, 2007 07:06 AM
larrykim
Feb 25, 2007 09:13 PM
supersport
Sep 12, 2006 02:10 AM
C4DD
Aug 31, 2006 01:32 AM
