Wind noise at over 80 mph!
Old Aug 14, 2006 | 02:33 AM
Pecemkr's Avatar
Default Wind noise at over 80 mph!
My car makes a very audible wind noise when I travel at 80 mph or above. It mostly comes from the passenger side between the window and the edge of the targa top. Does this happen to any of you? What's the solution?
Old Aug 14, 2006 | 04:07 AM
Dave01's Avatar
Default RE: Wind noise at over 80 mph!
Take the top off and lube all the relevant seals with dielectric grease. Reinstall the top and try it again.
Dave
Old Aug 16, 2006 | 01:59 PM
Pecemkr's Avatar
Thanks Dave! Where do I get this "dielectric grease?" Never heard of it before. How does this grease work? Will it make a mess with the glass?
Old Aug 16, 2006 | 10:13 PM
Dave01's Avatar
You can find dielectric grease at many auto parts stores (call first), your local Chevy dealership, and electric supply stores. Use it very sparingly and do not let it get on painted surfaces. You may have to wipe the upper part of the windows for a while after you apply the grease, but that's a small price to pay for silence. The C5 manual recommends greasing seals every 6 months, but I say it depends upon how often you pop the top. Every couple of years is probably sufficient for most C5s.
By the way, dielectric grease is typically used inside sparkplug boots and in electrical connectors. It keeps out corrosion-commencing moisture and prevents eventual connection failure.
Dave
Old Sep 15, 2006 | 07:38 PM
Pecemkr's Avatar
Thanks Dave!
Old Sep 16, 2006 | 12:12 AM
corvette king's Avatar
ORIGINAL: Pecemkr
try this stuff
http://www.madvet.com/shop?frame=873
WORKS GREAT!
stonecoldsaysto
Jul 30, 2017 12:36 AM
PinnacleWax
Mar 12, 2014 04:18 PM
fright88
Oct 18, 2006 10:54 PM
rjensen
Oct 2, 2006 11:12 PM
grandsport80
Sep 29, 2005 04:38 PM
