windshield washer inop
Old Dec 12, 2007 | 10:19 AM
w2w's Avatar
w2w
Default windshield washer inop
fuse ok; will not pump fluid; help...thanks
Old Dec 14, 2007 | 09:57 PM
Dave01's Avatar
Default RE: windshield washer inop
Check to see if the pump is getting power when the switch is activated. If it is, the pump may be bad. If it is not, the switch is probably bad (if all connections are good).
Good luck!
Old Dec 26, 2007 | 07:38 AM
kruser's Avatar
I had the same problem and it turned out to be the washer pump. The new pump was only 20 bucks and very easy to change. The pump is located underneath the washer resevoir and very easy to change out yourself.
w2w
Dec 12, 2007 10:19 AM
anzolv
Jun 5, 2006 09:21 AM
82vetteman
Mar 10, 2006 07:05 PM
redvet
Dec 17, 2005 02:20 PM
faleure
Nov 26, 2005 03:46 PM
