X-pipe...worth it?
Old Nov 9, 2007 | 07:04 PM
mutheta46's Avatar
Default X-pipe...worth it?
hey guys, I have an 04 Z06 that I have bought a new B&B Bullet exhaust for. Before installing I want to know if it would be beneficial to install an x-pipe, too. What are the benefits of the x-pipe with this install. Better sound? More power? Thanks for your help.
Old Nov 9, 2007 | 10:47 PM
chargedvette02's Avatar
Default RE: X-pipe...worth it?
Maybe a bit more power but the Z's flow pretty good already.
Old Nov 10, 2007 | 01:51 AM
84corvetteC4's Avatar
you will have a little bit better flow = a little bit better power = a little bit louder resonence in the exhaust(so it going to louder) oh nice choice on the exhaust they make a quality product.
P.S.the exhaust system will give you more power than OEM and in addition the X will make it more equal flow and free just make sure not 'free' it up too much or else you will loose all of your flow,backpressure and power.
Old Nov 10, 2007 | 11:18 AM
DeeVeeEight's Avatar
Banned
The x pipe will improve performance, but I disagree with it making your car louder. I experienced less of a staccato (pop pop popping) in my exhaust, it smoothed it out quite a bit. Inside the car is less noisy now too.
[sm=icon_cheers.gif]
Old Nov 10, 2007 | 05:16 PM
bados's Avatar
I think it gives you a little more power and it does smooth things out so that there is no irregular popping sounds.I'm happy with mine.
Old Nov 10, 2007 | 10:23 PM
Curious George's Avatar
ORIGINAL: mutheta46
The '99 C5 I bought a few months ago already had the Corsa cat-back exhaust w/ x-pipe already installed. It seemed a bit "peppy" with this exhaust. Good throttle response, etc. I was going back and forth between "Shorty" or "Long tube" headers for awhile, but eventually went with the shorties to utilize what I already had. I wanted something that bolted right-up, so I could do it (no welding, etc). Most long tubes require that you also purchase the high flow cats and x-mid pipe.
Anyway, I ordered the BBK shorties and installed them today. Took about 5.5 hours at a leisurely pace. Throttle response is very good and WOT is better, but I need a tune. Overall, I am satified.
CG
Old Nov 12, 2007 | 08:08 PM
butler68's Avatar
An X pipe helps but the best thing I did was take out the mufflers and put in some small 10inch glass packs.
Marty73
Sep 24, 2020 11:18 PM
whiteray
Nov 9, 2006 10:30 AM
mleonard
Oct 26, 2006 12:38 AM
D327
Sep 30, 2006 11:19 AM
94blackC4
Aug 1, 2006 06:51 PM
