Corvette C6 Forum 2005+
C6 2005 HELP Transmission leaking out overflow tube
Old Nov 7, 2010 | 12:46 PM
Jpalok9's Avatar
Default C6 2005 HELP Transmission leaking out overflow tube
I was at sebring raceway yesterday running my 2005 corvette thru the 3.7 mile road course. It was unreal how much fun I had. You really get an appreation for our C6 vetts out there on a road course. I was running with Porsche, Farreri, Lambo's, Vipers, Mustangs and more. The car performed great untiul the last run. When I got back in the pit I noticed the back of the car had this film on it like little dots of black between the exhaust and tailights When i started to wipe it off it was appearing like oil. Well I got underneath the car and there was quit a bit of fluid all over the sway bars and in the general areaa of the trans and rearend. I looked real hard and noticed that there is a tube that sits between the tranny and rearend and that was the area that all this fluid was producing the fluid. Im real nervous now as I dont know how much I lost and with our units being sealed I cant tell. I did notice later in the day the car starting to shift harder between 2nd and 3rd. I checked out the temp of the fluid on the raceway and it was running in the 270 degree area. Driving home the car ran fine shifted fine and I noticed the Tranny temp stayed at about 198 degrees the whole way home. Im just looking for some help here as to what I should do. Is this tube there so when the fluid gets so hot and expands that it blows out the tube. How do I know how much I lost and has anyone else out there had a simular problem
Thanks ahead for any input
Jim
Old Nov 8, 2010 | 08:25 PM
Yes, if there were no vent you would constantly blow seals due to heat expantion of not only the oil, but the hot air pressure would do the damage.
Finding tranny fluid under your Vette is a sign that you are low on fluid.
Check with the dip stick. Check your level and smell the fluid on the stick to see if it smells burnt.
Any doubts, change the oil and filter.
bls72bmw
Aug 30, 2015 11:03 PM
csyvarth
Oct 13, 2014 10:07 AM
txpd
Jan 2, 2007 12:00 AM
Petew1971
Mar 7, 2006 02:04 AM
jerrys
Corvette C6 Z06
Sep 3, 2005 07:13 PM
