Corvette C6 Forum 2005+
Cold air intake
Old Aug 2, 2007 | 01:01 PM
mhoglund's Avatar
Default Cold air intake
Is anyone running an aftermarket cold air intake? If so, which one are you running? There looks to be a 10-15 hp increase depending onwhich one you buy.
Old Aug 8, 2007 | 03:56 PM
mhoglund's Avatar
Default RE: Cold air intake
I did a little research over on LS1tech. It seems the Vararam air intake is pretty popular. Anyone here running it?
Old Aug 8, 2007 | 06:26 PM
I had one, as well as a Blackwing CAI. The Variram kit I got was hard to install and needed modification to fit (parts seemed warped), but others I've talked to got good kits that fit well.
Count on only 1/3 to 1/2 the HP addition claimed when you put a CAI on. I've dynoed before and after: about 3-6 RWHP increase depending on the model and type.
Old Aug 8, 2007 | 09:56 PM
tampabucs4's Avatar
we got my vararam in in about 15 minutes......... i bought the pre cut shroud that helped alot
Old Aug 9, 2007 | 07:57 PM
hogwild's Avatar
Did you have to do any work under the C6 or could it be done all from the top? I have no lifts or ramps to use
Old Aug 9, 2007 | 09:21 PM
Well, you have to access the underside of the front fascia, but you can do that with it on the ground on on ramps only a few inches raised.
Old Aug 15, 2007 | 09:19 AM
mhoglund's Avatar
The Vararam claims gains of 15 hp, 3 tenths off the quarter mile time and 3 mph on the trap speed. I'd really like to believe that but......it sounds to good to be true.
Old Aug 15, 2007 | 11:17 AM
Well, its not that expensive and it will help some. Even if you get only half that HP its still a fairly good deal.
rjensen
Feb 26, 2008 09:04 AM
50Cruzn
Sep 19, 2006 11:26 PM
gorichb
Aug 30, 2006 05:38 PM
rjensen
Aug 25, 2006 07:09 PM
jdavis
Jul 4, 2005 05:34 PM
