GM clutch or Aftermarket?
I'm building a 1966 Chevy Nova with a full C6 chassis and drivetrain. I'm going to call it ZO66 since I am modeling it after the ZO6 Corvette. My question is I bought a crate LS7 from Scogin Dickey and it came with the stock GM clutch. Should I run with this clutch or should I go with an after market one. If I go with an aftermarket one I am thinking of going with either a McCleod or Centerforce. Can anyone tell me which of these or any other brand would be best and what model has worked out for them?
I would go with a good aftermarket clutch. I've had good luck with Spec III. They shudder a bit until you get used to it, but it doesn't slip when you get into in and it won't burn.
Data:
Rear tires - 295/35/18 BFG KDW's
Rear Gear - 3.42's
Use - Mostly street, some strip, some Track. 80%/10%/10%
Weight of car - Around 3k
For a better idea of what I'm building:
http://www.lateral-g.net/forums/showthread.php4?t=4432
John
Rear Gear - 3.42's
John
