Corvette C6 Forum 2005+
GM clutch or Aftermarket?
Old Jan 17, 2007 | 04:31 AM
novanutcase's Avatar
Default GM clutch or Aftermarket?
I'm building a 1966 Chevy Nova with a full C6 chassis and drivetrain. I'm going to call it ZO66 since I am modeling it after the ZO6 Corvette. My question is I bought a crate LS7 from Scogin Dickey and it came with the stock GM clutch. Should I run with this clutch or should I go with an after market one. If I go with an aftermarket one I am thinking of going with either a McCleod or Centerforce. Can anyone tell me which of these or any other brand would be best and what model has worked out for them?
Old Jan 17, 2007 | 08:34 AM
extanker's Avatar
Default RE: GM clutch or Aftermarket?
ya gave nothing for data :eg tires,gear,street use,weight of car.so go with stock ls7 .do drill mod on all hyd. fluid restrictions and vent bellhousing my opine
Old Jan 17, 2007 | 08:01 PM
I would go with a good aftermarket clutch. I've had good luck with Spec III. They shudder a bit until you get used to it, but it doesn't slip when you get into in and it won't burn.
Old Jan 17, 2007 | 09:38 PM
Data:
Rear tires - 295/35/18 BFG KDW's
Rear Gear - 3.42's
Use - Mostly street, some strip, some Track. 80%/10%/10%
Weight of car - Around 3k
For a better idea of what I'm building:
http://www.lateral-g.net/forums/showthread.php4?t=4432
John
Old Jan 17, 2007 | 09:39 PM
Had any experience with Centerforce or McCleod? Which of the two is better?
John
Old Jan 17, 2007 | 10:02 PM
Both are good. I had one bad centerforce once, but I think that was just bad luck.
Old Jan 18, 2007 | 12:07 AM
Since most of the driving will be street are these clutches kind of fussy for this type of driving? I've heard if you slip them they will blow apart!
Old Jan 18, 2007 | 10:54 AM
extanker's Avatar
z06 clutch will be ample for your needs .my opine the after market units arent street friendly.they all need a break in period
Old Jan 19, 2007 | 01:09 AM
So you feelthe OEMwould be best for the usage ratio I posted above?
Old Jan 19, 2007 | 01:10 AM
You don't think an aftermarket would be too much for the usage ratio I posted above?
shoeless
Nov 14, 2006 02:43 PM
Woody
Jun 19, 2006 02:55 AM
Boshaft
May 11, 2006 01:41 PM
TXBear
Dec 14, 2005 10:19 PM
skyler_lloyd
Aug 17, 2005 04:47 PM
