Corvette C6 Forum 2005+
New radio
Old Aug 4, 2025 | 09:29 PM
KTM rdr's Avatar
Default New radio
I am installing a Kenwood radio in my 2013, (mainly for a back up camera) and was curious as to where the best place is to mount the satellite antenna. I am thinking of double sided tape on top of the vent outlets but wanted some input on where anyone else put it. I have a convertible and don't want to tear everything apart again, if possible.
Old Aug 5, 2025 | 06:22 PM
On my 77 the antenna lays on top of the dash next defroster vent, the wire goes through the vent not glued or taped. Then I have a carpeted dash cover that lays on top of it. works great. You have more slant in your windshield so it should work better. your double sided tape idea should work good.
Old Aug 5, 2025 | 09:32 PM
KTM rdr's Avatar
I'm not sure where the original sat antennae is located but I figured the vent location should work. It will be beneath the dash but no interference to the windshield. Just wasn't sure how the reception would be. It's magnetic and they recommend a flat metal surface. Good luck with that on a Corvette.
Old Aug 6, 2025 | 09:54 AM
The mounting the antenna on a metal base is to keep it from flying around it's not needed for reception. On some cars and pickups if the reception was bad on the dash then I went for a metal surface outside. I drove T-800 Kenworth's for years and could never get good reception with the antenna on the dash, Best reception was bolting a small metal tab with the mirror bolts that worked the best. That's a good question of where the factory siriusxm antanna is on the Corvette. Gm cars and pickups are almost alwawys mounted in the roof. Just make sure when you position the antenna it has clear view of the sky no metal blocking it. Windshield glass is ok.
Old Aug 6, 2025 | 01:13 PM
Most antennas require a metal ground plane. That could be the reason why they wanted mounted on a metal plate.
My '73 has a square piece of aluminum underneath the radio antenna on the rear deck.
Old Aug 6, 2025 | 07:52 PM
Sirius antanna doesen't need to be grounded like the AM FM radio's require. I have placed antennas on top of the dash and under without any performance issues. As long as there is a view of the sky.
Old Aug 11, 2025 | 08:53 PM
KTM rdr's Avatar
Placed it under the dash on the vent outlet with double sided tape. Works fine.
Old Aug 12, 2025 | 09:31 AM
Good I hope it works well, I have had Sirius for over 20 years, In work trucks and construction equipment (all it needed was a working FM radio) and all my personal vehicles Being in different parts of country and getting your favorite programs every day was great. Enjoy..
QuickNick
Nov 13, 2022 10:09 PM
Alans 94 vette
Jul 4, 2022 10:22 AM
DeeVeeEight
Jul 15, 2008 05:45 PM
dale
Jan 24, 2008 09:27 PM
deansreef
Mar 23, 2007 11:56 PM
