No Access dead battery and key to hatch doesnt work.
I'm in a jam. I have a 2005 C6 corvette with a dead battery and the rear trunk wont open with the key. How can i get the door open? Ive basically tried everything. Any suggestions/
Thanks
Thanks
Welcome to the forum. Can't really be of much help since I don't have access to a C6. Hopefully someone will come along and give you some ideas. I don't suppose there's anything in the owners l manual.
I wonder if you can access something from under the car to introduce a 12 volt supply and feed the car from there? Is there any way to reach the starter under the car when jacked up? I know on my 99 there is a pair of wires that feed the light under the hood. There has to be some place you can back feed the 12 volts positive and just ground to the chassis or any metal for the negative.
