Service Active Handling.
Firstly I want to say Hi to you all cos I've just joined. I am in need of tech advice and I came here to see if you guys might be able to give me some info. I have a 05 C6 with the power telescoping steering. The service active handling messagae and light has come on for some reason. It seems that there was a TSB re this problem on the 05 and 06. It could be either a bad connection with a plug in connector under the column (due to the telescoping action) or might indeed be the steering wheel position sensor ($72.50 for a new sensor at the dealer) that is faulty. I was going to either check the connector and if necc replace the sensor. My question is, what and how do I removethe padding/cover panel under the column and what wiring/connector should I be looking for and what does the actual SWPS look like and where is it located? The car is under warranty BUT I would prefer not to take it to the Chevy dealer if at all possible. Many Thanks in advance. Ken.
Hi and thanks for the reply. The car is under warranty but if I could have fixed it myself I would prefer to but electrical problems are difficult. I'm not happy about taking the car back to a dealer and all the hassle this sometimes brings but it may be my only option due to the nature/complexity of the issue. Thanks again Lee! Ken.
I hope it isn't the wheel speed position sensor. This is an issue with the C5 and I would have hoped that GM would have addressed thisin the newer C6. If they haven't I guess it must be cheaper for them to address the few issues while vehicles are still under warranty as oppose to fixing the root cause.
