Corvette C6 Forum 2005+
Synthetic Oil on aftermarket camshafts???
Old Jul 20, 2021 | 07:04 PM
MT53's Avatar
Question Synthetic Oil on aftermarket camshafts???
I recently experienced a lifter failure in my C6 Grand Sport, resulting in replacing the cam, lifters, springs, push rods, etc.
I'm hearing that when you go to an aftermarket camshaft, you should no longer use synthetic oil but use 10W-40 conventional oil instead.
Has anyone else heard of this???
I thought I'd throw it out there and see what the overall consensus is....
Thanks in advance!
MT53 in Atlanta
Old Jul 21, 2021 | 09:50 PM
I have never heard that before but you could always check with the camshaft manufacturer and see what they recommend.
Old Jul 22, 2021 | 08:41 AM
MT53's Avatar
Good advice, Shark. Thanks!
Old Jul 22, 2021 | 12:25 PM
Would be interested in what you find out.
Old Jul 22, 2021 | 01:04 PM
MT53's Avatar
I'll post it when I call BTR and Comp. It seems this may be the case for flat tappet cams, but not seeing a bunch of info supporting it for rollers.
Old Jul 22, 2021 | 02:25 PM
Northwoods79's Avatar
you might also ask about using break in oil ( high zinc content oil ) for the first 500 miles, this is done when you rebuild an engine for camshaft break in
Old Jul 22, 2021 | 03:56 PM
MT53's Avatar
I was wondering about that. Thanks!
Old Jul 22, 2021 | 11:37 PM
I don't believe the roller cams need the high zinc break-in oil but it can't hurt anything either.
Old Jul 23, 2021 | 07:47 AM
The high zinc break-in oil are essential for lubrication of not only the cam lobes but also the cam bearing surfaces and the crank bearings in a total engine rebuild. In your case where you replaced just the cam ( along with other related components ) it will have to go through the heat cycle to harden the lobe surface, typically running the engine at 2000 RPM’s for 20 minutes.
Old Jul 23, 2021 | 10:14 AM
MT53's Avatar
I saw a couple of videos relating to that. Thanks, Northwoods!!
