top rubber molding replacement
If the rubber molding, or whatever the correct word is, on your 2007 coupe has faded to gray from the original black color take the car in and GM will totally replace it, no charge. The molding is on the front, rear and sides of the removable top. The rear piece comes all the down to the top of the door. GM says it should not have faded and should remain black. I should hope so considering the price of this car. Just had mine replaced yesterday.
Not sure about the TSB, I took my car to the dealer (Phoenix, AZ) and complained and the service mgr told me GM was aware of the problem and would fix it, which they did. Several other vets have also had the rubber replaced here recently.
jmtrotzie
May 4, 2007 12:38 AM
