Corvette C7 Forum 2014+
Right side problems
Old Aug 6, 2020 | 11:56 AM
philvett2019's Avatar
Default Right side problems
2019 corvette I have a problem with my vett i swap the wheels out for 19x9 front 20x10.5 for the rear and the right side rub when i go over a large dip in the ONLY THE PASSENGER SIDE ???? any ideas for any one
Old Aug 7, 2020 | 11:51 AM
Remember that these cars have a plastic body and they are usually a little bit different from side to side. I had a similar problem on my 73 when I went to a wider tire on different wheels.
Old Aug 10, 2020 | 10:37 AM
Good morning
how did you fit it ?
Old Aug 11, 2020 | 09:33 AM
It required trimming some fiberglass on the inner edge of the fender flare at the rear of the opening. It was a very minor amount of removal.
Old Aug 11, 2020 | 07:17 PM
Default Phil
Thanks for your help but i can't do that !!!!!!
Old Aug 11, 2020 | 09:56 PM
Are both front and rear hitting? Are they hitting up inside the fender? One thing you could try would be to put on a taller bump stop and see if that helps.
RBB
Jul 17, 2020 06:43 AM
buddymgd
Oct 29, 2011 09:09 PM
Monica
Oct 17, 2008 05:14 PM
AXE
Oct 24, 2007 01:25 PM
gmaredd
Oct 22, 2006 02:40 PM
