2000 C5 sticking clutch
Unballanced clutch disc would make the most sense. Every time i floor it, its always made a thumping sound. Ill be switching to a brass bushing and a new prop shaft moveing foward. I was the one who put the clutch in 10k ago. Its poddible that i put the wrong grease in, been too long to remember but i know it came greased to start.
It was an LUK kit
It was an LUK kit
Its the same type of bearing that's in the back of an alternator, and I have never had one of those go bad. Old and worn but not bad, goes to show it can happen. I had worked on an old Honda 70s civic years back and had the engine out and noticed it had no pilot bearing or bushing on a manual trans. And what I found was it didn't require one, at that time I couldn't find one that would fit. I always thought that was strange.
Without doing research isn't the outside diameter on a bronze bushing larger than the roller bearing? And is that a option? C-5s had the roller bearing and the C-6s had a ball bearing. I'm sure a bronze bushing could be machined down to the roller bearing size easy enough to fit. You have me courious I need to look into that.
