2013 corvette rear bump stop
I have had a metal to metal sound on bumps, coming from the left rear.Pulled the real wheels of today and the left bump stop is almost non existant. Only the bolt going through the end of the spring and there is about an inch gap between the bottom of the stop and the a-arm where the stop sits on the swing arm. The other one looks fine. No clue what happened to it. One of my question is will that make the bump-bang metal sound on bumps? My other is will it make it sit lower on that side. The left side sits 1 1/2" lower than the right side. The end of the left spring sits about 1" lower than the one on the right side.
*I also would like to buy one if you have one that maybe you removed when you installed a lowering kit.
