77 corvette ignition problem
Old Oct 19, 2014 | 09:14 PM
Barzini's Avatar
Default 77 corvette ignition problem
key is getting stuck in ignition when I turn to start, anybody know how I can fix this problem?
Old Oct 20, 2014 | 07:18 AM
I would start by replacing the ignition lock assembly. It is relatively easy to do. You need to pull the steering wheel.
Old Oct 20, 2014 | 12:12 PM
Barzini's Avatar
I took apart the steering wheel and got down as far as the turn signal. I don't know how to get passed that and was told not to take that apart.
Any advice?
Old Oct 20, 2014 | 08:59 PM
You'll need a tool to push the steering wheel plate down against the spring to allow removal of the little wire lock ring. That will allow it to be removed from the shaft which IIRC will get you access to the ignition after removal of the turn signal stuff.
I think I got my tool from JC Whitney but it was about 30 years ago.
SuperHeroSmurf
Jun 14, 2012 06:58 AM
ehudley
May 1, 2010 10:41 PM
old mac
Jul 6, 2008 12:54 PM
jess_p
Nov 15, 2005 01:19 PM
LLL
Jun 15, 2005 04:33 PM
