80 Vette shifter boot installation
Hi, I just bought an 80 Vette and want to change the automatic shifter boot. I have the new boot and thought I'd ask before I tore the whole dash apart. I need to know how to remove the shifter panel. Thanks. Harleyboy52
[IMG]local://upfiles/4137/401AE8CD53D4421AB5B4C206C88BBB67.jpg[/IMG]
The only tricky part of tearing out the center console... there is a little plastic thing attached to the shift lever that points to the P_R_N_D_2_1
under the see through plastic. If you forget about it, it will snap off when you tug on the black plastic console.
Fortunately, they cost like $3, but can put a wait into your project while Ecklers ships you a new one.Other than that, the job is straight forward, nothing really tricky. Remove the side carpetted pieces, unscrew the console itself (obvious once the sides are out of the way, 2 screws on each side or something like that), slide out the **** indicator needle, unhook the switches, open the ashtray door, and you are there.
For about $40, you can replace the black plastic console itself while you have it ripped apart...bill.
Thanks Bill, I figured that the console was attatched on the sides but I didn't want to try to tear out the carpet sides until I was sure. Thanks again. I'll install it tomorrow.
I replaced the leather boot on my 79 and didnt have to remove the console. TWIST off both *****, remove screws that hold boot in, slide boot off, install new boot. the rubber boot is a different story or your year may be different.
Hi Phill, I was just going out to try to replace it and saw your reply. My new leather boot has a metal rectangular rim around the bottom of the leather. I don't think that this metal will go in from the top and mount under the console. I think that mine has to be put in from the underside. I'll let you know in a little while.
