air con question? pics ...
Old Dec 12, 2007 | 04:14 AM
gingerbreadman1977's Avatar
Default air con question? pics ...
in my 81 ipulled out the motor to dress it up a bit. in doing so i took out all the computer and wiring that goes with it. i have made a mistake and now i dont know where the air-con power plugs in. ill post some pics to explain my problem.In the engine bay the green wire comes from the compressor and then through the low pressure switch, after that there is a single pin connector close to the hi speed fan relay.. from this point on where should the wire connect into???????im assuming some point under my centre consol????( circled in PINK is the connector where my green wiring no longer continues, where does it go from here??) please any one?
91vetteny
Jun 17, 2008 12:24 PM
Apr 17, 2008 10:29 AM
jmccormick
Mar 20, 2008 02:41 PM
zanderwitaz
May 26, 2006 01:49 AM
jd2000
Dec 11, 2005 04:15 AM
