Battery Drain
Old Sep 24, 2007 | 08:21 PM
jsnest87's Avatar
Default Battery Drain
I have an 87 convertible with a new sealed battery that gets drained in about 5 days. I have used a trouble light in-line on the ground cable and pulled every fuse, but the light remains on. Alternator seems to be charging. It is draing enough amps that a battery saver will not work.
Anybody having a similar problem or can steer me in another direction.
Thanks............
Old Sep 24, 2007 | 09:25 PM
pg's Avatar
Default RE: Battery Drain
Hi jsnest87, Since you did all the other tests I'll guess theres a bad diode in the alternator, heres how to test it http://www.4wheelnoffroad.com./alter.html Hope that helps, PG
Old Sep 24, 2007 | 10:02 PM
ORIGINAL: jsnest87
Seems???
Did you put a multimeter on the field terminal of the alternator?
riley6riley
Nov 8, 2007 04:25 AM
07c66speed
Oct 14, 2007 07:39 PM
racerrick
Sep 8, 2007 09:19 PM
kdr
Aug 26, 2006 03:06 AM
crvttbass
Mar 31, 2006 09:25 PM
