Dash Display Problem
Old Aug 8, 2009 | 07:06 PM
fille9's Avatar
Default Dash Display Problem
Re: My 88.. My digital dash is dim, distorted and frozen. Nothing works.. Any advice or help grateful. Thank you
Old Aug 17, 2009 | 04:07 AM
vamanan's Avatar
I recommend trying this first in Firefox Menu bar > View > Zoom > Reset. If That doesn't work then I recommend contacting Support because they have access to the back end components.
Betfair Poker rakeback Machines а sous
Old Aug 17, 2009 | 04:22 AM
ayan1000's Avatar
I propose the standard collection of analog gauges in a car be replaced with a large high-resolution color LCD display -- the kind of high-quality display they use in modern aircraft that can self-adjust to be easily viewed in all lighting conditions. This display would not have to be in the boring rectangular shape typical of LCD displays. Instead, it would have the smooth shaped curves of a typical automotive gauge cluster.
Rakeback Absolute Jouer casino
Old Aug 19, 2009 | 04:27 PM
vettemanrob's Avatar
Have you tried the groung wire? My 96 digital display would not show sometimes so I took it in and they said it was a bad or loose ground. Once fixed everything worked perfectly.
GSjoe
May 2, 2011 12:54 PM
fille9
Aug 19, 2009 09:58 AM
mmikeclass06
Nov 3, 2008 09:27 AM
marcslaff
Mar 21, 2006 12:18 AM
