dimmer switch '93 C4
Old Oct 15, 2008 | 06:43 PM
scotth48's Avatar
Default dimmer switch '93 C4
Is the dimmer switch on the column up at the turn signal or is it on the column lower, taking out the carpeted panel. If so is there a rod that goes to it. Mine will not go/click to high beam. at least it is stuck in low beam to drive at night.
Thanks
Scott
Old Oct 17, 2008 | 08:06 PM
Curious George's Avatar
Default RE: dimmer switch '93 C4
If I am not mistaken, it is "up" at the turn-signal end of the steering column. It could also be the high beam relay if there is one. Can't remember off hand. If the assembly does not even "click" then it is definately the turn-signal mechanism.
CG
Old Dec 16, 2008 | 05:11 PM
bryanth73's Avatar
dimmer on the coloum about 2/3 rds down connected by a metal rod
TripleBlackC5
Oct 15, 2007 07:14 PM
Bagpipingjake
Jun 20, 2006 02:02 AM
jadrfld
Feb 25, 2006 06:17 PM
keverson
Nov 4, 2005 09:26 PM
jotto
Oct 27, 2005 08:56 PM
