Fuel psi
Your car should have three lines at the tank, the 3/8 inch is the largest and is the supply from tank to pump, the 1/4 or 5/16 steel line that runs next to the 3/8 is to bleed off excess pressure from the pump back to the tank like when the engine is at an idle and not using all of the fuel the pump is putting out. The only other line should be on the driver side frame rail, it runs from the tank to the charcoal vapor storage canister in the left front fender, you should not see liquid fuel in that line.
Texas Jim
Feb 15, 2008 09:35 AM
