Fuel psi
Old Jun 20, 2007 | 02:15 PM
drummerjlc3's Avatar
Default Fuel psi
Should I have a steady stream of fuel returning to the tank through the vapor return line? And would this cause me to have low fuel pressure with new strainer and fuel pump.
Old Jun 20, 2007 | 02:17 PM
78buckshot's Avatar
Default RE: Fuel psi
What type of vehicle and what year?
Old Jun 20, 2007 | 02:22 PM
1979 L82 Corvette coupe
Old Jun 20, 2007 | 02:35 PM
78buckshot's Avatar
Your car should have three lines at the tank, the 3/8 inch is the largest and is the supply from tank to pump, the 1/4 or 5/16 steel line that runs next to the 3/8 is to bleed off excess pressure from the pump back to the tank like when the engine is at an idle and not using all of the fuel the pump is putting out. The only other line should be on the driver side frame rail, it runs from the tank to the charcoal vapor storage canister in the left front fender, you should not see liquid fuel in that line.
Old Jun 20, 2007 | 02:39 PM
Ok so then everything is working proper in that way. Thanks for the reply
Old Jun 20, 2007 | 02:48 PM
78buckshot's Avatar
You don't need or want high pressure at the carb, about 5 psi is all you need but you do want enough volume to feed the motor at max throttle.
SpeedyKev64
May 25, 2014 10:34 PM
23outlaw
Jun 9, 2010 09:28 PM
Texas Jim
Feb 15, 2008 09:35 AM
CStewTAMU
Jan 18, 2008 06:39 PM
DAYUIZ
Mar 17, 2007 05:36 PM
