Gas Gauge on 98 C 5
Old Apr 19, 2009 | 09:10 PM
bubber's Avatar
Default Gas Gauge on 98 C 5
After I drive about an hour or so my gas gauge goes to empty no matter how much is in the tank
Does anyone else have this problem ?
Any idea how to correct it with out taking the tank out ?
Thanks in advance
Old Apr 20, 2009 | 02:11 PM
I vaguely recall there was a service bulletin about bad sending units or something, -- sorry I can't be of more help.
Old May 19, 2009 | 02:24 AM
heejun's Avatar
Old Jun 17, 2009 | 03:49 PM
vettemanrob's Avatar
Bubber, I have the same problem from time to time. Someone on here a while back told me to start using only shell gasoline since they have numerous cleaning agents added. Also at every oil change I use a fuel system cleaner, berryman to be exact and I have had very little problems since. ( every now and then I cant get to a shell gas so I use whatever available. )
Old Jun 17, 2009 | 07:22 PM
Toms94's Avatar
I recently traded my 94 for an 01. The day I brought it home, this issue popped up (scared the living poo-poo out of me). Anyway I started reading up and someone said "Seafoam" will take care of the problem. So I bought a can and dumped it in the gas tank. I left it setting in there a week or so. Last weekend I took the Corvette on a rather long trip, 1000 miles one way, and guess what? The gauge works like a new one.
It's cheap enough that if it doesn't work you're not out much, but it's likely that it will fix it.
I've also heard Techron additive will work too, but on my 99 Silverado it didn't work and I replaced the sending unit. This was, of course, before I knew about Seafoam. To alleviate the problem use the Shell, Chevron, Texaco fuels. Chevron and Texaco have the Techron in it, Shell has it's own version.
wilton
Aug 30, 2009 05:32 AM
gilbert786
Mar 20, 2009 06:20 PM
3434JJJ
Jun 21, 2007 06:18 PM
badsax
Jun 9, 2007 11:11 AM
KenHorse
May 15, 2007 08:07 PM
