the heat will not work
Old Jan 31, 2008 | 06:36 AM
dale's Avatar
Default the heat will not work
The heat will not blow in the car, the cool air will,so I took my 1994 corvette to the chevy dealer, and they ordered a new actuator to open and close some type of door under the dash, well they put the new one in and they cant get it to work. They were trying to reset the computer to make it work, any ideas, Thanks
Dale
Old Feb 2, 2008 | 10:53 PM
Default RE: the heat will not work
Tell us that you told them to re-install your old equipment??? And that you then left with all the cash that you went in there with???
Old Feb 13, 2008 | 10:46 AM
moscooter's Avatar
Wow, I don't think I wanna know the labor cost to R&R that "door" you are talkin' about. They have to pull off a good part of the dash to get in there and do that job.
Cars (used to have) heater control valves. The heater core is a (mini-sized) radiator. With the valve closed, no heated water flowed thru it and thus you had no heat in the car. Now, there is NO valve and the heater core has continual flow. The "door" opens/closes to allow heat from the core into the passenger compartment. Yours must be stuck closed.
Mine was stuck partially open, thus I had some heat along with a/c. Somehow it became (unstuck) and all is well. Good luck.
riley6riley
Jan 18, 2009 10:17 PM
williadg68
Jun 23, 2007 10:20 PM
Black86vette
Jan 28, 2007 09:00 PM
Renes98
May 1, 2006 09:55 AM
faleure
Oct 11, 2005 03:10 PM
