High Oil Pressure
Old Oct 29, 2006 | 08:03 PM
rtrusse1's Avatar
Default High Oil Pressure
I have a sudden indication of very high oil pressure in my 2001 coupe, anyone ever here of this?
Old Oct 29, 2006 | 08:11 PM
Default RE: High Oil Pressure
What is "high pressure" how high?
Under what conditions?
Does the indicatied oil pressure vary at all? How and when?
Old Oct 30, 2006 | 08:19 PM
Black86vette's Avatar
Need more information? Do you have the digidash? If so it could be a glitch in the sensor. Always check your sensors before throwing money away. Dont replace it unless its broke...
Old Nov 2, 2006 | 07:35 PM
SCHOON's Avatar
I wouldn't be worried about high oil pressure it's the low pressure that recks you ride.
Old Nov 2, 2006 | 08:18 PM
I had an experiance with high pressure, turned out to be a clogged passage and FRIED a main bearing.
Old Nov 2, 2006 | 09:40 PM
Yeah, high oil pressure usually means: 1) some oil passage is clogged (one thing to worry there is, what is clogging it and where did it come from?), and 2) something at the end of that clogged passage is not getting oil, which is ultimately very bad.
It is best to get this checked out. Could be a bad sensor, or a sign of trouble to come that you can repair before it is too late.
Old Nov 2, 2006 | 10:09 PM
High oil pressure, if true, could also be a stuck check valve in the oil pump. I also would like to know what you are calling high? [8D]
vettemanrob
May 27, 2008 02:44 PM
pewter2000
Jan 29, 2008 11:15 PM
z.oh.6
Jan 4, 2007 10:54 PM
gjswt19
Dec 13, 2006 01:11 AM
Vet Head
Oct 31, 2005 02:17 PM
