Idle problem after warm up
Old Jul 8, 2009 | 09:57 AM
alive69's Avatar
Default Idle problem after warm up
90-L98-60K mi.- 1 owner-Starts great, warm up smooth, 5 miles out I get the rough idle and surging throttle as I drive. New dist. cap and rotor, new plugs with 300 mi. on them, Ohm test on the plug wires shows good wires. New battery and alternator in last year. Have not tested fuel pressure due to no guage. Am thinking it may be fuel or vacuum related. Fuel filter and fuel pump are original. One note: I show the car at indoor shows a couple times a year and I do not drive it very often. Last winter it set for 5 months in the garage. Would appreciate some sound advice or even experienced speculations. I think I might be getting to old for this hobby but love my Vetts. Thank you.
Old Jul 9, 2009 | 06:22 PM
DeeVeeEight's Avatar
Banned
First off - do you use fuel stabilizer? Your car sits a lot. It sounds like you may have sour gas in the tank, that will make anything run poorly - or not at all. Secondly - try using some Techron (Chevron) Fuel system cleaner with some fresh high octane gas and getting it out on the highway to clean it out (translation = FLOOR IT ! !). Third - is your oil level where it should be? Not enough oil can cause hydraulic lifters to not have enough pressure and contribute to rough idle. Fourth (am I counting right?) - maybe there is a sensor going bad like a map or maf sensor..... damn computer controlled cars need all of their input data to be "happy" otherwise they act stupid. And lastly - how's the air filter? Engines like a rich mixture when cold but not when hot - a clogged air filter can cause a rich condition - something else to **** off your computer.
I hope that helps, at least it is the stuff you can check or try yourself. If these don't work then it's time to take it to the shop and let them figure it out.
Old Jul 14, 2009 | 08:46 AM
Curious George's Avatar
I would check your EGR. This will cause surging if it is not operating correctly.
CG
deansmachine
Sep 11, 2008 07:08 AM
Vetteatlast
Apr 6, 2008 06:41 PM
Callipjm
Mar 6, 2007 09:42 AM
06 Vette
Jan 23, 2006 10:24 PM
Richvette
Oct 5, 2005 12:39 AM
