Newbie Question-running warm
Old Apr 3, 2008 | 06:00 PM
Vetteatlast's Avatar
Default Newbie Question-running warm
I want to replace the thermostat on my 86" corvette to a 160 degree thermostat and was wondering if the throttlebody has to be removed to change it or will there be enough clearance without removing it Thanks!
[IMG]local://upfiles/7322/218F489C330F43098E2E734C5A362BAC.jpg[/IMG]
Old Apr 3, 2008 | 07:31 PM
grease monkey's Avatar
Default RE: Newbie Question-running warm
it's not necessary to remove the throttlebody. i changed a few and had just enough room.
Old Apr 3, 2008 | 08:19 PM
Not too hard unless you have fat crooked knuckles like me...but I still was able to do. Go for it!
And welcome to the site. Don't forget the wave. Cheers
Old Apr 3, 2008 | 10:35 PM
Changing your t-stat to a 160 degree might affect performance. TPI are designed to run 195 - 205 heat range. Fuel injection and combustion is more effecient at that temp.
Old Apr 3, 2008 | 10:47 PM
It did mine. I put in a 160 T-stat and lost a little. put the 195 back in and it runs great. They make chips to go along with the 160 T-stat but I didn't change that. May make a difference but the car runs great like it is so....
Old Apr 4, 2008 | 03:44 AM
Thanx everyone for responding: I really appreciate it
Old Apr 4, 2008 | 03:33 PM
Would I benefit from changing my thermostat to 180degree thermostat ,the last time I drove the vette I saw temps of 210 degrees and both fans were working properly and it wasnt on a warm day.it only has 28,300 miles on it
Old Apr 4, 2008 | 06:02 PM
I kinda doubt it. You might need to get the radiator cleaned. If you take it out, have it rodded.
Old Apr 6, 2008 | 06:41 PM
LeesVette's Avatar
Those temps are normal.
charliebebo
Sep 5, 2009 06:32 PM
deansmachine
Sep 11, 2008 07:08 AM
Callipjm
Mar 6, 2007 09:42 AM
06 Vette
Jan 23, 2006 10:24 PM
Richvette
Oct 5, 2005 12:39 AM
