lt1 compression results
Old Nov 15, 2008 | 03:47 PM
bryanth73's Avatar
Default lt1 compression results
Well my 93 lt1 has antifreeze in the oil so I started to a compression test. With wot and all plugs out dry results are 84,85,85,95 on left bank 85,85,85,95 on right bank theese sound low to me any idea where I should be for a stock 93 corvette lt1???
Old Nov 15, 2008 | 04:17 PM
YANKEECORVETTE's Avatar
Default RE: lt1 compression results
Your compression pressures are too low. Shoot some oil in each test cylinder and retest. The antifreeze might have deluted the oil and washed the cylinders clean. You might have to drain the oil out of the motor if the test fails again. A min. pressure should be a no lower than 125psi.
rjensen
Jul 7, 2007 08:52 AM
rjensen
Jul 6, 2007 05:11 PM
Pecemkr
Jun 21, 2007 10:15 PM
Aperformance
Corvette C6 Z06
Aug 17, 2006 04:22 PM
Red03SVTVert
Sep 27, 2005 06:46 PM
