95 vette was running rough until....
Old Mar 25, 2007 | 09:23 AM
deansreef's Avatar
Default 95 vette was running rough until....
My car was running rough and would almost stall at the light. When crusing and press the gas it would hesistate sometimes and the instant gas miles would drop very low when crusing at a steady RPM. The SERVICE ENGINE LIGHT would also come on and go off at times.
The solution: I changed the 02 sensor and the problem is gone. The mechanic checked the computer for codes after the replacement and all is working nicely now.
Old Mar 25, 2007 | 10:54 AM
Black86vette's Avatar
Default RE: 95 vette was running rough until....
Just a 02 sensor caused that much of a problem? That is serious issues. I should check into that on my car. Thanks for the tip![&:]
Old Mar 25, 2007 | 12:27 PM
deansreef's Avatar
the sensor was seriously ganked up upon inspection causing the computer to dump gas on the problem. this in turn casued the gas mileage to dump and relay other problems.
Old Mar 26, 2007 | 10:36 AM
LeesVette's Avatar
ORIGINAL: Black86vette
You betcha a 02 sensor will cause those problems - they can cause major havoc.
pushrodracer
Aug 11, 2007 02:03 PM
ernie22golf
Jun 19, 2007 06:32 PM
markcuc
Oct 6, 2006 04:45 PM
dparsons
Oct 5, 2006 09:36 AM
lifelesslived17
Jan 27, 2006 11:34 PM
