Nickel block
Old Apr 6, 2007 | 09:02 PM
Default Nickel block
Hi folks, I have an opertunity to purchase a fresh.030 over 4 bolt nickel block 350 for $150.00. Should I? Cheers
Old Apr 7, 2007 | 09:42 AM
78buckshot's Avatar
Default RE: Nickel block
Hey blueshark, sounds like your reffering to the alloy make-up of an iron block, from what I've read the mixture can run from plain cast iron up to 10% tin and 20% nickel, you could have a combination of the tin and nickle or only one of these metals mixed with the iron. The 10% & 20% combo is reported to be best, the tin helps control expansion and contraction, the nickel hardens the block and provides a longer lasting smoother bore. If you've checked the block for cracks and/or other damage and all looks good then I would say $150 is a fair price, it would be best to have the original main caps with the block so you won't have to align bore as would be the case with any other main bearing caps.
Old Apr 7, 2007 | 10:39 AM
Sounds good to me!
Old Apr 7, 2007 | 07:04 PM
It came out of a 1ton truck and is in impeccable shape with a fresh bore. The main caps are with it, as well as some peripherals. Thanks for the replies. The same guy has a second fresh .030, 4 bolt cast iron block. What might that be worth?
Old Apr 7, 2007 | 09:02 PM
Well if I need some 350 parts, I know where to go!!!
Ahhhh.....a hunr'd bucks for the second block.
hester
Dec 6, 2007 12:11 PM
jbrigman03
Aug 9, 2006 12:18 AM
57halfton
Mar 23, 2006 07:41 PM
DaveM
Jul 3, 2005 03:19 AM
thirdtimevetteowner
Jun 6, 2005 09:36 PM
