Performance
Old Aug 22, 2012 | 06:40 AM
Tristaner's Avatar
Default Performance
Intense speeds, controlled stops
When a luxury sports car is capable of a test-track top speed of 198 mph, it better have impressive brakes as well. Z06 uses monoblock 6-piston front calipers and 4-piston rear calipers, while the extra-large 14-inch front rotors and 13.4-inch rear rotors are vented and cross drilled. And launch control is standard with the short-throw 6-speed manual gearbox. It modulates engine rpm to lay the power down more smoothly while providing consistent acceleration times on the test track. Brembo® Carbon Ceramic Brakes — a braking system that helps with performance, weight and corrosion resistance — along with the Michelin® Pilot® Cup Tires, that offer 8% more grip than the standard tires, are also available as part of the Z07 Performance Package.
Old Sep 16, 2012 | 08:50 AM
ThomasMcCrory's Avatar
I think you’ve made some truly interesting points. Not too many people would actually think about this the way you just did. I am really impressed that there is so much information about this subject that have been uncovered and you did it so well, with so much class. Thanks.
bmbndb
Aug 31, 2005 10:49 PM
MerrionRJ
Aug 4, 2005 02:09 PM
bRKrbcing
Jul 20, 2005 03:27 PM
casper
Jul 1, 2005 08:14 AM
bmbndb
Jun 13, 2005 09:33 PM
