pulls to left when braking, 1977 vette
Old Sep 21, 2005 | 03:39 PM
artdunn01@netzero.co's Avatar
Default pulls to left when braking, 1977 vette
my 1977 vette pulls to left when braking, then goes right. brake pads and rotors are good and wheel bearings are good. does anyone have this problem and whats the solution? any help much appreciated. thanks, art
Old Sep 21, 2005 | 08:50 PM
Patrick's Avatar
Administrator
Default RE: pulls to left when braking, 1977 vette
i know that you already said that the braking components were good, but are you Certain that you have pressure at all 4 corners? i have dealt with a 76 with the same problem, that had a caliper that wasnt working properly.
Old Sep 28, 2005 | 09:15 PM
crvttbass's Avatar
I agree with Patrick, double check the operation of your calipers. If one is hanging up or is lazy for any reason, the one that is functioning properly will grab first causing a pull then the lazy one comes on and because your already countersteering will seem to pull the car the other way. I had a friend with this problem and his was in the caliper.
Old Oct 19, 2005 | 10:34 PM
Rickracer's Avatar
Jack the front up and spin both wheels. Both should spin a relatively equal amount of revolutions. Make sure your wheel bearing are tight/no play too. If all that checks good, you may need hoses. Everything to do with brakes should be done in pairs. Hoses, calipers, pads, packing wheel bearings, etc. [sm=shades.gif]
Old Oct 20, 2005 | 03:03 PM
Patrick's Avatar
Administrator
excellent point rick.
monte_350
May 14, 2022 02:02 PM
MBR04
Jan 1, 2009 07:13 PM
outcold
Feb 10, 2008 10:46 AM
colemajo
Jan 25, 2008 12:01 AM
bddman
Sep 20, 2005 01:10 PM
