Storage
Old Jan 2, 2008 | 09:45 AM
Garry123's Avatar
Default Storage
Since I live in a colder climate I store the Vette from Nov - April.
I do these things
-Fill tank withgas and add stabilizer
-Park car on a carpet to reduce moisture
-Cover car with a breathable cover
-Star a run for a good 1/2 hour every 2-3weeks
Any other suggetions ?
[IMG]local://upfiles/6930/4EC74FE260054F5BAAD0517F703A6A14.jpg[/IMG]
Old Jan 2, 2008 | 06:39 PM
Default RE: Storage
Roll your windows down a couple of inches, so moistureisn't trappedinside the car.
I put the car on blocks( stands ) to get the tires off the ground to prevent flat spots.
I'm goin' to move your post to the General Tech forum. Better place all around.
Old Jan 3, 2008 | 06:26 AM
Garry123's Avatar
Default RE: Storage
Great advise .............. I do roll down the windows approx. 1/2 inch all year round.
I also heard, from the Local Corvette club, that spreading a bit of " No Touch Foam ", on the rubber around the Targa top and all windows and doors, helps keep the rubber from cracking. I guess you know what a new set of rubber cost ?
Thanks
Old Jan 3, 2008 | 07:57 AM
Default RE: Storage
....and don't forget to add some anti-freeze to your headlight fluid, ya don't want any cracked lenses.
Old Jan 3, 2008 | 08:46 AM
riley's Avatar
Default RE: Storage
I don't run mine that often in the winter but I do keep a battery tender on it.
Old Jan 4, 2008 | 04:59 AM
watwheel's Avatar
Default RE: Storage
Never have done anything when storing my vette. I simply remove the battery and store in the house,throw down a carpet, throw the car bag down, drive on it, throw the dust cover over it, toss some dry packs in the bag and zip it up. Good to go all winter. NEVER had a problem getting her up and running on the first try. Been storing her that way for 32 years!!
Old Jan 7, 2008 | 11:55 AM
Garry123's Avatar
Default RE: Storage
I leave the battery in the car but it drains in about a week. So Ineed to charge the battery1 / month when I fire it up.
The Battery is blocked by that control module thingy over top of it. ( See bottom right hand corner of picture.)
Iwas thinking of getting a trickle charger. What do guys think ?
I guess you can tell that I am not that mechanically inclined. That's why this site is the best thing I could have ever seen.
[IMG]local://upfiles/6930/E47D966D697A417E86A3DA97610FAABA.jpg[/IMG]
Old Jan 7, 2008 | 06:48 PM
Ric's Avatar
Ric
Default RE: Storage
Gary I use a charger also but I use a float charger there is a difference in chargers. The float charger only charges win it calls for charging so it wont over charge the battery. you can leave them plugged in the hole winter session. Also I put moth ***** in the car and underthe hood this helps with Mice.Mice love the silicone plug wires.
Good Luck
Ric
07 Blue Jet Z51
Nov 21, 2007 07:17 AM
carlmeyer1
Oct 23, 2007 08:45 AM
Black86vette
Dec 14, 2006 04:13 PM
countryboy48080
Nov 12, 2006 06:02 PM
mypetu39
Sep 2, 2006 09:10 AM
