want the ultra blue lights
Old Mar 11, 2007 | 05:38 PM
aspmaster's Avatar
Default want the ultra blue lights
What or how does one get those ultra blue white lights instead of those old incandescants? I want it to look as stock as possible but I want those new bulbs.
What are the issues involved?
Asp
Old Mar 11, 2007 | 05:43 PM
Default RE: want the ultra blue lights
As I understand, you can only do that with the halogen bulb inserts. Haven't seen the the old "yellow" bulb conversions. I like your idea, I've thought about it myself.
Old Mar 11, 2007 | 06:39 PM
78buckshot's Avatar
I'm pretty sure you can replace the incandecents with drop in halogen sealed beams, what year/stly of lights are you talking about? You can visit a bunch of webs on automotive lighting and choose your poison.
Old Mar 11, 2007 | 08:04 PM
You can check some of the big supplier catalogs, like Exklers, etc. -- I know they have the "Lemans lighting kits" for the C5 with halogen, assume they have them for others. Some of these kits get expensive and complicated -- they actually have fans to cool the bullbs, etc., so shop around if the price of the first one you see puts you off.
Old Mar 11, 2007 | 10:43 PM
wrwalke's Avatar
I've seen them, but they are way expensive to do it right. You can go with halogen replacement sealed bulbs as someone else said. I did that with mine to get some brighter headlights. Total cost about $30-40 or so.
If you want the "projector" bulbs, or HID, you are looking at $500-1000 depending on the quality of the kit. They require a ballast setup, and lots of new wiring. Your old headlight circuits probably won't handle the load well. One kit that I checked out used the stock wiring to a relay circuit that turned on the bulbs. This allowed them to fade on/off, which is supposed to extend the life of the bulbs. The HID itself was powered by a fused direct line to the battery, or to the power block side of the fuse panel, using 10g wiring. I just replaced a ballast on the Navigator to the tune of $600... The bulbs are also quite expensive, $100-150 each.
bill.
Old Jun 8, 2007 | 07:53 AM
Tkul's Avatar
Take a look at this site. It’s my favorite for all lighting needs http://autolumination.com
shevey
Sep 23, 2008 10:19 PM
IVAN1215
Technical Diagram Help
Sep 24, 2007 01:50 PM
Wedge
May 28, 2007 10:24 PM
NHRADRAGRACER
Jun 25, 2006 06:30 PM
adelii
Jun 28, 2005 02:51 AM
